跳转到主内容
Repair manuals and information for the Microsoft Surface line of tablets.
128 个问题 查看全部
No screws under kickstand?
Hi There:
I've been asked to replace the lcd/digitizer in a first generation Microsoft surface RT. Any guide I've been able to find online shows a number of screws visible under the kickstand once you remove it. The RT has no visible screws under the kickstand?
Am I dealing with a "first" first gen device? Strange that I've not found any online instructions about this.
Thoughts? Has any one else run into this version of the RT. Am I venturing into heat gun !&&*?
As requested, here's a photo of the tablet:
Thanks in advance.
kevin
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论:
could you provide a picture of the area of the device you're describing?
完成的
Sure, I'm back onsite next week, I'll snap a photo then.
完成的
Photo added to question.
完成的
添加一条评论
3个答案
Are there screws on the areas I annotated? In the guide it shows that there are screws there.
这个答案有帮助吗?
得分 0
2条评论:
Yes, I can remove the kickstand. The two screws to do so are located as annotated. Those are the only screws visable
完成的
In step 4 of this guide you can see that you need to remove plastic bezels in order to gain access to the screws.
完成的
添加一条评论
I have run into the same thing. There are no Torx screws around outside edge of surface rt under the kickstand. Furthermore, there are no Torx screws under the plastic cover around camera. Any guidance on how to get to the battery on this unit?
这个答案有帮助吗?
得分 0
添加一条评论
Has anyone been able to open this tablet? I have the same one and am trying to open to replace the battery. As indicated there are no screws besides the screws for the kickstand.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 307
