跳转到主内容
Released in October of 2014. This model, SM-G530H/DV Samsung Galaxy Grand Prime, comes in a White, Gray, or Gold casing.
148 个问题 查看全部
My phone wont start up
My new phone wont start up!
I've only used it for 3 or 4 days... My phones battery was low and i put it on charging.After some time i checked it wheather was fully charged or not. It was charged 95%.. I put it on charging for some more minitues. When i checked after some time it was off.. I tried everything and it wont start up. Visited the service center and they said that they think its board is dead..It was an abroad phone.. They said that i should give it back to the shop that it was purchased. They could only fix the phone...I cant give it back to the location where it was purchased. So please help me!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 15
4条评论
Somebody please help me
完成的
Mera mobil restore hogeya hai
An naya gmail nahi is raha h plz help
完成的
My phone Grand prime plus is not starting in battery its only staring in power supply please help me what shod I do?
完成的
mara sumsung galxy grand prim google accot ni bana rha
完成的
添加一条评论
2个答案
已选择的解决方案
Jho Lewis,
  • Connect you phone to charger : make sure that your charger is working properly
  • let it to charge 15 Mins
  • Remove phone from Charger
  • press and hold together: Volume Up + Home button + Power button for a couple of seconds
  • Connect phone to charger and charging should appeers only if your PM still functioning
这个答案有帮助吗?
得分 6
3条评论:
Nothing happened! Phone wont startup! Feeling bad :-(
I've just used it for 3,4 days only!
完成的
it seems to be motherboard fault. why don't you claim the warranty?
完成的
Ok mine just keeps on flashing samsung long. It doesn't go past that
完成的
添加一条评论
ok so first there is a hole by where ur headphones go stick something that can fit in that small hole for 10 seconds that will reset ur phone but not ur email.
这个答案有帮助吗?
得分 1
2条评论:
plz i updated my grandprime to lollipop, after showing d "samsung grandprime" name,d phone wont come up
完成的
Please, anyone to help. My samsung grand prime plus is not displaying it's name when turned on like 'SAMSUNG GRAND PRIME+' please help
完成的
添加一条评论
添加你的答案
Jho Lewis 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 31
总计 47,693
