跳转到主内容
由华硕制造的笔记本电脑。
2523 个问题 查看全部
Why does my Asus Laptop u48e shut off?
The computer keeps shutting down right in the middle of anything that is running. Even when no programs are running. Seems as though a power supply problem, same if on battery, which is new and fully charged, or when connected to the AC power source. Asus says it is hard drive problem, but not 100% sure. Upon re-boot, comes on saying shutdown problem, and asks if safe mode or not? Sometimes runs for 10 minutes, sometimes hours until it shuts off. Tried setting the laptop on a cooling pad, but still shuts off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I purchased a new fan for the CPU. It has been 2 days since I installed it, and it has not shut down. Working great so must have been the overheating CPU. Many thanks for your help.
完成的
添加一条评论
3个答案
已选择的解决方案
It has been about 2 years since replacing the cpu fan, and the computer is still working.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
hey Robert,
Can you take a look tot the bottom of the laptop. See if the cpu fan is running, if not try to start the laptop, normally it has to run for a few seconds, if not this is the problem.
i had the same thing.. its a build in security so the cpu can't overheat, the laptop will shut down to protect the cpu.
if not,
there's a big change it will be the motherboard..
good luck and let us know..
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Ford 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 422
