跳转到主内容
Xbox One Kinect. Included with the Xbox One. It has successfully sold over 23 million units around the world.
22 个问题 查看全部
Why does my Kinect keep going through power down/up cycles then stop
My Kinect 2 for Xbox One keeps powering down and back up again then eventually doesn't come back on and shows the 'not plugged in' icon in the top right corner.
I could hazard a guess that it is over heating and shuts down as a safety precaution? If this were true maybe the fan isn't working. Should the fan be on all the time or only when it is hot enough?
How can I get an actual fault code out of it? And assuming I can get a fault code, where can I look up what it means?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
9条评论
Are you in the preview program? This seems to be affecting a lot of people including myself. The fan doesn't seem seized, it's just not turning on.
完成的
My Kinect started doing the same thing well before I joined the preview program, so I'm doubtful that they're related. I'm anxious to see if anyone on here finds a solution as I've had to completely unplug the device from my system now and wouldn't mind getting it back for the dance games I purchased for my kids.
完成的
It was the fan. I replaced it and everything is good now
完成的
I decided it was probably the Kinect itself rather than software, but as this particular kinect broke previously too and the fact that being out of warranty it was going to cost £50 to get it repaired, I instead bought a second hand one from webuy.
It turns out the second hand one was newer than mine so that was a bonus.
I have had this second hand one for over a month and it has been trouble free, which for me confirms it as hardware and not software.
The second hand one by the buy was half the cost of the repair!
完成的
There is a post on Giantbomb, in which a user states that a fuse located at j11 is blown, thus causing his Kinect to not turn on. He said he couldn't source an identical part. I wonder if a similarly rated fuse would get it back running again?
Does anyone around here have a fried kinect, that they could check this on?
完成的
显示更多的4条评论
添加一条评论
5个答案
最有帮助的答案
The fan may have died on mine. It's not seized, but appears to be the most likely culprit. I ordered a new one, and I'm going to swap it out. Wish me luck, $16 is way better than $90
这个答案有帮助吗?
得分 1
4条评论:
How did this turn out for you?
完成的
It was the fan. Been working like a champ ever since the incredibly hard disassembly/reassembly. You must reinsert the cable BEFOREreassembly, and I ended up removing the shock mount rubber because otherwise I couldn't get it back together
完成的
Did you use the same fan for replacement or you used another part number or manufacturer?
完成的
Same fan, as Microsft used
完成的
添加一条评论
I just bypassed the j11 thermal fuse that had blown back in 2015 not long after my post, I needed it badly so I just figured I would solder 1cm of some 8amp 2.7mm auto cable to replace/bypass the thermal fuse and it's worked ever since.
Now before you say it, yes I know what the risks were frying my kit, I am an experienced registered domestic electrician and an ex Royal Navy marine engineer, It was just supposed to be a temporary measure.
But let me tell you this my Kinect 2.0 hasn't just worked, it has excelled!
It has rarely ever been powered down, and it has for years now done 6 hours a night every night of hard hard work on twitch
Replace it with the correct fuse if you can find it, but just to let you know mine has been fantastic.
这个答案有帮助吗?
得分 1
添加一条评论
No I am not.
I bought a second hand Kinect 2 from ' webuy' which arrived this week. So far this seems to be working fine which suggests it is a fault in the Kinect.
as my Kinect was a couple of weeks out of warranty I would of had to pay to get it fixed, which would have been £50 and then I'd get 3 months warranty. Buying a second hand one from webuy (which is not as old as my own) was only £35 and that comes with a 12 month warranty...so now I have a spare Kinect. I may open it up to see if it were something trivial, like a loose wire, but I don't have much of a clue with electronics.
这个答案有帮助吗?
得分 0
添加一条评论
i have to strip mine and test the fan and fuse, but i dont mind if its not an identical part, plus if i cannot find the correct fuse i may try and bypass this completely and go for broke,
ive not used it for 6 month now so its not a problem if i break it, i just want to tinker
这个答案有帮助吗?
得分 0
4条评论:
Hi bobby I've found some fuses on eBay there not the same but there as near as an they work well here is the UK eBay item number 121428294599 good luck I hope it fixes it as it did mine
完成的
i just found fuse on taobao,https://item.taobao.com/item.htm?id=3709...
price is $0.02 each
完成的
On small delicate electronics alway replace the Fuze. Just always. If you are going to go for broke get a fuse that seems reasonable to the situation. Many times you can figure it out simply by knowing the voltages and just measuring the current across the fuse when device is running.
Now don't get me wrong, I'm not recommending this but almost anything is better than no fuse.
Fuses are cheap compared to a new kinect.
完成的
Hey bud how do you bypass the fuse and also if the Kinect turns on and off ,is it for sure the thermal fuse that's needs to be replaced or something else because it turns on so that means the fuse does work and is malfunctioning or is it something else
完成的
添加一条评论
I have this problem too, first i replaced a new fan ,but it didn't work, then i think it was the temperature control unit, i had no idea to fix the temperature control unit,so i cut the blue and yellow lines on the fan,Although it is not perfect,but it work. side effect the fan always on unless power off.
这个答案有帮助吗?
得分 0
1条评论:
This is what I think is happening with one of mine, the fan does spin up, but there will be times it still shuts off and on repeatedly (Xbox or PC, and may happen just under an hour of use, and then randomly at random intervals). It could be a thermal pad issue as one other commenter mentioned in another thread, where the fan is properly controlled but I guess either isn't cooling it well enough, or the temperature control is defective as you state.
完成的
添加一条评论
添加你的答案
Stuart Wells 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 22
总计 5,251
