Dropped my phone now I have colored lines on the entire screen
I dropped my iPhone 5c on a hard surface, and when I picked it up I saw pink/red lines across the screen. After I hit the lock button, the screen is normal but after about 10-30 seconds pink and red vertical lines appear across the screen and it stops functioning until I press the lock button again. Is there a way to fix this problem or does the LCD screen need to be replaced?
Just happened to mine and it won't work but I can never get service and I got it after I dropped it
由 Connor 完成的
I have a 5s I never dropped it or boyging I went to check the time n there was a green line so I cluxked the power button and it never turned back on , can I take it somewhere yo be fixed or is it done for?
由 Jolon 完成的
Is this optional? I can live with the lines in my screen. I just want to know if I dont fix it, nothing bad would happen.
[After I wrote this comment I noticed the lines faded away. You'll be fine. Sometimes they fade away. Just wait.]
由 HiHowAreYou 完成的
My phone fell and it started like blinking with no-colored lines on the screen. I hit it again to see if it stopped, and it did, but then I turned it off for it to "rest" for about an hour. When I turned it on, the blinking appeared again. It still works but sometimes it stops and sticks in the screen. What can I do, rather than changing the LCD display. Plzzzzzz helpp!
由 Silvana Calvo 完成的
Don't worry I have a iphone 5 SE and that happened to me I let it sit for 5 minutes went back to normal
由 Yunetzy 完成的
显示更多的20条评论
