跳转到主内容
A helpful collection of toaster repair and disassembly guides.
57 个问题 查看全部
It's sparks when I try to push the lever down?
I turned it side ways and and pushed the lever down it worked and then I cancelled it and put it upright!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Sounds like you have a shorted or broken heater coil wire. Unplug it, visually exam it for a break or a wire touching the sides and test for continuity with a multimeter.
这个答案有帮助吗?
得分 1
添加一条评论
Mine was sparking because of a piece of food on the electo-magnet.
After cleaning my toaster outside with my hose-end sprayer with soap in the dispenser (Miracle-Gro hose-end sprayer) then letting it dry for a few days, I plugged it in and pushed it down and it Sparks inside... I took it apart and found a piece of food product had burned into the electromagnet. I cleaned it off with a fingernail emory board. Then I put it back together and it works great!!!
I'm sure a dishwasher works just as well.
Also, I heated my oven to 150°, then shut the oven off and put the toaster in for about an hour to be sure it was dry. Don't let the cord touch anything hot.
这个答案有帮助吗?
得分 0
1条评论:
Who would even do that?
完成的
添加一条评论
Are you trying to get someone’s house burned down? Maybe you think it’s funny, or that nobody would actually do that. But there are people who might, and that’s on you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Casarah Acosta 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 42
总计 3,194
