跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Apple hardware test without battery
I have got clear answer about 4SNS/1/40000000: ICOR - 21.926 error from previous answers but I have forgotten to say that I didn't have battery in my Mac during the test.
Do I need to make Apple Hardware Test with battery and connect my power supply or I can do it without battery? Does it any relation to result of test. Could be error 4SNS/1/40000000: ICOR - 21.926 as result testing without battery?
Thanks for answer
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
Can you give us some background here on whats happening.
完成的
I forgot to say that the logic board on this laptop was replaced few weeks ago. Because the previous one was completely dead. I think that the replaced used logic board has errors.
完成的
When I run Apple Hardware Test with battery there wasn't any errors. Thanks a lot for advise!
完成的
添加一条评论
2个答案
已选择的解决方案
You may want to run this app to see whats happening with your battery: coconutBattery. Paste a screenshot here so we can see.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I would definitely run the test with BOTH the battery and the power cord inserted.
Since your specific error code points towards an issue with current, having the battery in may alter the sensor result.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
greytl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 487
