跳转到主内容
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
camera and volume button not working after reassembly
Hi there,
I successfully replaced the LCD on my HTC M7 following the guide. Everything worked until my LCD stopped working probably cause it was a bad quality aftermarket product. I bought a new LCD assembly and replaced it again.
After installation, everything worked fine except the camera app wouldn't start (I reinstalled the whole ROM, and it still didnt work so I thought it's a hardware issue). So I disassembled the phone again, took out the daughterboard to check if I accidentally ripped something or broke something on it, but it didnt seem so.
I reassembled the whole phone again, but this time not only the camera wouldnt work, but also the volume button didnt react. I tried bootloader mode too, but the volume buttons still didnt work. Any suggestions?
Could it be any of the cables that connect the daughterboard to the motherboard? Ambient light sensor, jack plug, upper loudspeaker all work so Im hoping I dont need to replace the whole daughterboard. Any tips? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
The camera it self most likely needs to be replaced, electronics are extremely sensitive to static discharge it takes only about 10 volts to fry microchips. humans can not perceive static electricity until it reaches around 1,500 volts.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Istvan Weyda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 169
