跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 个问题 查看全部
问题已关闭
Solution iWatch crash after UNICODE string. ( Stuck in booting)
When your Iwatch is crashed during the unicode string and is stuck on booting you can simply resolve this problem.
Solution for this problem is to wait till the battery of the Iwatch is TOTALY empty. You can check this by pressing the button and no screen is given. Then recharge it and the Iwatch will reboot normaly and will functional normaly again.
Most people make the mistake they drain the battery but not long enough. The Iwatch will give the message to charge the Iwatch.
So be sure the screen of of the charging image will not be displayed anymore... Then the battery is totaly empty.
Hope this will make alot of Iwatch holders be happy again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
here you can find better answer
这个答案有帮助吗?
得分 0
1条评论:
Read first begore you aswer. Its a solution when you got the Unicode message where your iphone/iwatch will crash. This is the way to fix it m8
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 635
