跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Is Mid-2015 Retina SSD compatible with my mac?
Hi, I'm using Late-2013 MacBook Pro 15" Retina (Harswell processor).
According to tech spec of the new Mid-2015 MacBook Pro 15" Retina (Froce touch trackpad version), it has nearly 2.5x faster SSD in it.
I wanna know is it compatible with my MacBook Pro 15" Retina version or not.
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Sadly, no.
The way Apple did this was to add I/O lanes. The older PCIe SSD had 2 lanes the newer model offers 4 lanes.
The M.2 interface offers the ability to support 16 lanes. But the logic within the system needs to support these lanes. Basically the older systems can't.
这个答案有帮助吗?
得分 4
1条评论:
Thanks a lot, Dan!
完成的
添加一条评论
Hi, I wanted to understand this . So would the 2015 drive atleast work with the 2013 machine (at the older 2013 speeds) or is it completely incompatible .Thank you so much. You would clear up a lot of my confusion. :)
这个答案有帮助吗?
得分 0
3条评论:
While Apple is doing their own thing here lets see if we can leverage the M.2 standard here for clarity. Please review this doc: Wikipedia - M.2 Standard. Here we can see the keyway of the M.2 card & slot defines the interface dialog. In the case of M.2 it would be A for PCIe x2 & M for PCIe x4. So in the case of M.2 standard one can't insert just any blade drive in as the location of the keyway needs to fit.
OK, lets look at Apple's SSD blades. Apple has used so far four different SSD's. In addition the SSD's firmware has also been altered so even with the correct physical SSD it won't work in all the systems that support the same physical connector. So you need to use the correct part for the given system for the older systems (mSATA, SATA based SSD's).
完成的
Now lets jump to the last few years when Apple appears to have settled down a bit. Today Apple is supporting both PCIe x2 & x4 lane SSD's which appears to have the same physical interfaces. Apple has not disclosed what is interoperable between the series and the part numbers across the systems are unique.
If we look at the SATA interface which used a common physical interface standard there was (still is) a lot of confusion on what is interoperable. So someone with an older SATA I based system has to be careful what drive they used as the drive may not play nice in their system. If you review a lot of the questions here you'll see people encountering problems until they put in a drive that supports SATA I in these older systems.
完成的
So in this case Apple or the 3rd party needs to give us guidance on what is interoperable between Apple's custom SSD units or someone needs to be willing to do the needed testing to see what is workable. So far no one of good authority has stepped up to do this testing (nor have I).
So I can't give you an answer if the older PCIe x2 systems will support the newer PCIe x4 SSD's or if the newer PCIe x4 systems support the older PCIe x2 SSD's.
Given the cost of the SSD's and having messed up a few by putting them into the wrong system I would recommend you not try unless you are willing to take the loss (SSD or even the system).
Just like driving, its best to stay on the correct side of the road even if it looks like you can drive on the other side. Only problem here is you may end up in a nasty crash without knowing until its too late ;-}
完成的
添加一条评论
添加你的答案
soono87 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 753
