after replacing my cracked screen the back light does not show again
after replacing my cracked screen the back light does not show again, i can see the writings when i flash a light on the screen, how can i fix this problen?
You’ve replaced the screen with the wrong model or the screen is with the wrong manufacturer (use the model and manufacturer on the old screen) or the connectors are bad or the backlight is broken. Check the connectors , try cleaning them up. If problem persists, replace the screen with the right manufacturer and model and make sure the backlight won’t be broken on the next screen.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 74
