跳转到主内容
Repair and support information for HP Laptops, designed for home and home office use.
Power shutoff within a few minutes even in BIOS using AC
The HP Pavilion ze4420US laptop formerly had a problem turning it on, where you had to press the power switch many many times to start, but then it stayed on. Now it comes on with the first push, but goes off again at a random interval from a few seconds to 15 minutes. This happens even in BIOS setup, so it's not the OS (Win2K). And it happens whether on battery or AC power, even with the battery out. I suspect the power switch itself. Anyone else see this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Answering myself here. Took it to a local repair person, who ran a memory test from a bootable CD that revealed a RAM failure. Replaced memory stick, all is well. The BIOS mem test did *not* detect this problem. Thanks all!
这个答案有帮助吗?
得分 1
1条评论:
Wow, awesome. Glad to hear you got that cleared up. Thanks for posting the solution.
完成的
添加一条评论
最有帮助的答案
It sounds as though you are having overheating issues. When the computer gets too hot, it will turn itself off to prevent frying important parts. The time it takes for the computer to reach the critical temperature can vary with a number of factors, which is why the computer will sometimes shut off right away, and sometimes will run for several minutes. One way to tell if you are having overheating issues is if the fan is running overtime.
I'm not sure what to make of the past power switch issues. It is certainly possible (and probable) that these two issues are related. Possibly you could open up the laptop and check for loose connections.
Best of luck.
这个答案有帮助吗?
得分 1
1条评论:
I am including a link for downloading a manual for your computer. Good luck. Ralph +
http://www.retrevo.com/d/ds/progress?doc...
完成的
添加一条评论
添加你的答案
Jeremy Griffith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,089
