跳转到主内容
Released in 2010 and 2011, the G73 is a series of gaming laptops from Asus. Model numbers include G73JH, G73JW, and G73SW. All versions use an Intel Core processor and dedicated graphics card.
Are the fans for the GPU and CPU the same?
Are the fans for the GPU and CPU the same on ASUS g73jh laptop?
Just need to replace them but need to know if the GPU one is the same as CPU one.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
I have replaced the faulty fan, and I removed them both for cleaning and both the GPU and CPU fas are exactly the same, just one is mounted face down , that why they look different in the guide, but they are 100% interchangeable and the same.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
They should be the same, most laptops with multiple fans use the same fan over the cpu and the gpu.
这个答案有帮助吗?
得分 2
添加一条评论
here you can fine the answer
https://d3nevzfk7ii3be.cloudfront.net/ig...
这个答案有帮助吗?
得分 2
2条评论:
from the picture ,actually they look like they are the same, I will just order the fan once I have opened up the computer and verified that they both are the same.I will be sure to post my finding here.
完成的
完成的
添加一条评论
添加你的答案
Sebastian Edinger 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 3,605
