跳转到主内容
A network storage device available for home or business use.
1 个问题 查看全部
Power status light blinks, indicating failure. HD clicks. Is that all?
I inherited a Maxtor Shared Storage II NAS. After sitting unused for some months, it now won't work; the drive makes a clicking noise periodically (I know that's not good), plus the power status light on the front blinks freen, continuously and rapidly, which from some googling indicates failure. I tried the reset, no joy. Not visible on network.
Question is: should I just junk it, or will replacing the drives possibly fix it? I don't even know where the OS is stored--in firmware, or on the drives?--and don't want to spend a lot of time on it myself. If there's a chance it's just the drive, I'll yank the drives out (it's my client's data) and sell the enclosure to someone who cares to fiddle with it.
I did find lots and lots of posts online about these failing, but a lot of them had to do with the Seagate drives inside, which may have fallen victim to the firmware bug last year.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I would first remove the internal drive mechanisms (isn't this a dual drive unit?) and test them
the clicking sound doesn't sound promising, that's likely a drive about to go. but I've also seen several external drive enclosures with dead interface logic, meanwhile the internal drive was fine. anyhow if this is a dual drive unit, then perhaps you can at least salvage one drive and reuse in another external enclosure.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, I'm not worried about the drives (new drives are cheap enough), just wonder if it's worth trying to salvage the enclosure.
完成的
添加一条评论
添加你的答案
colleenthompson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 33
总计 2,975
