跳转到主内容
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 个问题 查看全部
Microphone stopped working after screen replacement
Hi,
I replaced my screen on my nexus 5 and now the microphone is not working when making calls! When I click the mic on google now it says unable to open microphone. When I make a call on speaker phone the caller can hear me fine.
Any suggestions would be great.
Thanks,
Jamie
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
You need to apply some pressure in proper place to mic cable contact.
Check out this video:
https://www.youtube.com/watch?v=P8XpdqOf...
In my case, a thick 2-side tape helped me out with up side not peeled.
这个答案有帮助吗?
得分 2
1条评论:
with this help of the video this worked for me :)
完成的
添加一条评论
Same problem here. Any solution?
这个答案有帮助吗?
得分 0
添加一条评论
If anyone has this issue again I found a fix. So this happened to me and after taking it apart again a couple of times I noticed the plastic wedges at the top and bottom you remove have a small hole with a channel through. I guess I put one back in upside down blocking the sound to the microphone. Put it back together again and it works like new!
这个答案有帮助吗?
得分 0
添加一条评论
Hi Everyone,
I also face same problem as you all,
recently i get solution for it.
1) Open back cover of nexus5
2) Put some thik paper above battery though the distance between vibrator of back cover and bettery is increase and vibrator not touch to mother board bettery.
these problem may arise because of vibrator touch to the mother board..
I have personally experience to solve it.
Thanks,
Yogesh Patil
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jamie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 2,956
