跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
"Sim Not Valid" on activation, faulty sim reader?
I am aware the obvious answer is "are you stupid, that means you're trying to insert a sim that the phone doesn't support because it's locked" however let me explain myself. i purchased this iPhone from a friend who has been using it on EE, when i got it, i accidentally ripped the battery connector off the motherboard so had to send it off to be re-soldered. I got it back, and it was on the activation screen where it says "hello" in all the language. After inserting about 5 different SIM cards all on different networks, it still says "sim not valid", even though i used the sim from my phone which i know works. It also says "no service" at the top so i am dreading that the sim reader may be faulty? Any suggestions would be appriciated!
Jacob
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
i have iphone 4s ios 8.3 sim not valid..how to fix this phone
完成的
添加一条评论
1个答案
最有帮助的答案
Click the power button to blank the screen. Then click home button to wake up. Then touch the "i" info button. The imei number will pop up, and if your lucky, beneath that will be the SIM card number. You may have to wait I min for that field to populate.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jacobrsmith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 813
