跳转到主内容
Sony Handycam released on April 10th, 2009, identified by model number HDR-XR500V.
3 个问题 查看全部
Where is the internal battery? as you change?
Sony hdr xr500V Where is the internal battery? as you change ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I found that even replacing battery caused my date/time settings to reset. Purchased my HDR-XR150 back in 2010 (now end of 2021). Lately, with cell phone pic/video quality improvements, this camera isn’t getting as much use as it used to.
I’ll try charging for extended period of time to see if that helps. When possible I’ll try to switch battery while camera is plugged in-let’s see if that helps.
Thanks!
完成的
添加一条评论
1个答案
最有帮助的答案
It is an internal rechargeable battery that is not intended to be replaced. The manual said plug it in for 24 hrs to recharge it or leave a battery attached. It will last for 3 months if the camera is not used. I now just leave a battery attached to the camera and when I took it off and put back on after a week it was keeping the date and time. Hope this helps.
这个答案有帮助吗?
得分 3
1条评论:
Thank you. I couldn't find an answer to this problem anywhere. Much appreciated.
完成的
添加一条评论
添加你的答案
nombre00 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 45
总计 4,341
