跳转到主内容
14" business laptop released in 2014. One of the first Haswell business laptops on the market.
13 个问题 查看全部
Why doesnt my computer work properly?
I dropped my laptop from a table.After dropping from table it worked for sometime and after sometime my HDD LED light didnt work.When I tryt to open computer the screen goes white and opens after longtime.Te HDD light glows for sometime and gets off.My computer works when the HDD light gows but get dead when it is off.How can I solve my problem?Is my motherboard dead?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hi, It sounds to me that your hard drive was damaged when you dropped your computer. You probably need to replace the hard drive and install a fresh copy of the operating system. If you don't have a disk you can probably get one from Dell for a low cost. I am providing a link on replacing the hard drive. Hope this helps.
http://blog.parts-people.com/2014/10/28/...
这个答案有帮助吗?
得分 3
1条评论:
I agree with rj713. You most likely damaged the platters in your hard drive when you dropped it. If you can't get data off it that you need, check out SpinRite from Steve Gibson's Gibson Research Company. The link is http://www.grc.com. Once you've recovered the data (if you can), install a new HD in the computer - I recommend an SSD, which has no moving parts - and reinstall your operating system.
完成的
添加一条评论
添加你的答案
Pradip Thapa 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 744
