跳转到主内容
加入维修社区 - 创建账户
亚马逊 (Amazon) 开发的一款便携式电子阅读器。维修过程简单直接,仅需撬具和螺丝刀即可完成。
Kindle Paperwhite Repair code comes on after screen replacement
Can anyone help me with a problem. I replaced my kindle paperwhite screen and now I get the screen saying repair needed. Battery invalid:-22. I am glad the screen works.....
Help??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
Did you find any solution to this?
I have exactly the same problem. I assembled a paperwhite 2nd-gen screen with a paperwhite 1st-gen motherboard and get exactly the same error.
EDIT (typing mistake): it was a 2nd-gen motherboard and a 1st-gen screen
这个答案有帮助吗?
得分 0
2条评论:
Where did you find a screen of 2nd gen? I need to replace mine.
由完成的
Oh sorry... I mistyped something. What I meant was i assembled a "paperwhite 1st-gen screen and a paperwhite 2nd-gen motherboard"
由完成的
添加一条评论
Received a 2nd-gen screen today, still getting repair-message.
这个答案有帮助吗?
得分 0
5条评论:
It's not good. Last week I bought this one http://www.ebay.com/itm/311350255136 (2nd gen screen to my 2nd gen motherboard) and I'm waiting to receive it. I hope not to get the same message because I don't know how to deal with it.
由完成的
The message is "Battery invalid:-22.", correct? Did you try to disassemble and connect the battery again? Or a hard reset?
由完成的
That's correct! Yes, I tried both. My current approach is to try it via serial connection. Maybe it's just a software-issue that could be fixed that way. Has your screen arrived yet?
由完成的
Hello, men! So, what with your Kindle now? A you repair it? I have a same problem now.
由完成的
由完成的
添加一条评论
Any solutions? I have same problem
这个答案有帮助吗?
得分 0
添加一条评论
I came across a russian site http://kindle.zzweb.ru/paperwhite/repair.... Basicly it sates this:
  1. Connect the Kindle Paperwhite to a computer USB-cable.
  2. Create an empty file in the root directory DO_FACTORY_RESTORE.
  3. Safely disconnect the reader from your computer.
  4. Reboot your device by holding the power button.
I did this and my kindle paperwhite did a factory reset and I was able to use it again. I had previously tried to format the drive and place a firmware update on the drive so I do not know if this will remove your books. Please try and back up your books if you can before you do this.
Hope this helps others.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sdinovitz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 3,195
