跳转到主内容
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
1004 个问题 查看全部
Will not awaken from sleep if cover is closed
If I leave the MacBook open, it will go to sleep automatically. I touch any key and it awakens normally. If I close the cover to put it to sleep, when I open
the cover, it does not awaken. I have to restart it as if I had shut it down.
What must be done to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
First, I would Restore Defaults in Energy Saver preferences, here is how:
  1. Choose System Preferences from the Apple () menu.
  2. Click the Energy Saver icon in the System Preferences window.
  3. Click the Restore Defaults button in the Energy Saver window.
  4. If you are on a Mac notebook computer, click the Battery or Power Adapter tab to switch settings. Click the Restore Defaults button in both panes if needed.
Source: https://support.apple.com/en-us/HT204760
Second, make sue the following is taken care of:
  1. Make sure the computer's battery is charged. Try connecting the power adapter to the computer, then press the power button for one second to see if the computer powers on.
  2. Make sure the AC power cord is connected securely to the power outlet, and that the outlet it is working correctly. Confirm the power adapter or cable is attached firmly.
  3. If your computer is plugged into a power strip, make sure the power strip is not turned off. Check to make sure other items connected to the power strip are receiving power.
  4. Confirm the right power adapter is connected on Mac notebook computers. If a lower wattage power adapter is used than the one that came with your Mac, it may not provide enough power to charge the battery while the computer is powered on. Make sure there is no debris in the MagSafe port that might prevent charging. When your MagSafe cable is connected properly, you should see a green or orange light on the connector.
If you're still having issues, you may want to reset the a SMC and reset NVRAM/PRAM.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John Bowers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 84
