跳转到主内容
加入维修社区 - 创建账户
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
IPAD red fuzzy screen replace LCD?
I attempted to replace the digitizer on an ipad 2 and since then the screen is doing the red fuzzy thing. I have tried unplugging and plugging the LCD connectors and doing the drop/slap solution but it is still red and fuzzy. Is this an issue with the LCD itself or with another component? I can replace the LCD if need be.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论:
Thatnks for the reponse. I have tried all the above. The logic board and connectors look absolutely fine. I have ordered a new lcd cable just in case but i dont think this is the issue. Would replacing the lcd solve this problem or is it another part that is at fault?
完成的
75% can be solve replacing LCD, 25% it can be motherboard fault. Change the new display and let me know the status, if same fault observed i will help you to fix the fault on logic board.
完成的
Ok thanks. I will keep you informed.
完成的
添加一条评论
2个答案
Try to reboot first
  • Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds
  • Check the module contacts fixed properly to logic board
  • if fault remain same plug the device to iTunes and see whether device detected or not
  • Try to Restore via iTunes
  • If all steps not works for you, you may have to get new module
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem also on an iPad 2 eventually found a bad conection on cap just above the r47 filter reworked it and all was good
这个答案有帮助吗?
得分 0
3条评论:
Ps I tried other LCD's I have all the same red fuzzy stuff around the images
完成的
Isnt the 4r7 coil for the backlight? The backlight on mine seems to work fine its just the image itself which is bad. I was hoping that it was the actual LCD that was bad because i can easily get a new one...whereas fiddling with the smaller components is a bit beyond me.
完成的
Simon Milo Mitchell Jones, you are correct. 4R7 is LCD back light Driving inductor. but there were capacitor and diode filtering output visuals but i don't think that your case is coming from filters.
完成的
添加一条评论
添加你的答案
Simon Milo Mitchell Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 219
