跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。型号为A1532, A1456
Cannot slide to unlock screen
Phone will not unlock, there is no password, it just will not slide to unlock. it wasn't dropped, wet or anything else. My settings are supposed to come up even when screen is locked but that isn't working either.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Sounds like a faulty digitizer. Is it responding to your touch at all? If not, you can check the connections, maybe clean them with some isopropyl alcohol on a cotton swab.
If it still doesn't work after that, you'll probably have to replace the digitizer. You can choose between this: iPhone 5c LCD and Digitizer which would require you to switch out the home button and front camera, or you can buy this: iPhone 5c Screen with the home button and front camera included.
Replace a screen compatible with iPhone 5c. Includes all of the small parts preinstalled in the assembly. 4 inch 640 x 1136 pixel LCD Display, Front Glass Digitizer Panel, Front Camera, Earpiece Speaker, LCD Shield Plate.图片
产品
iPhone 5c Screen
$34.99
Replace a scratched or cracked front glass digitizer panel or malfunctioning 4.0 inch 640 x 1136 pixel IPS LCD compatible with the iPhone 5c.图片
产品
$39.99
这个答案有帮助吗?
得分 2
添加一条评论
First before you take apart the iPhone like its stated below try the simple thing that's most likely to work try a hard reset..
Hold power button and home button together for 7 seconds then let go of home but keep pressing power this will restart and hopefully the touch will work
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Nelia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 432
