跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Some problems after Battery replace
Hi,
I have changed my battery and i have a lot of problem...
First i have change the battery and i have a problem, the Touch Id doesn't work.
In Settings when i want to activate it, it's written "Fail".
I don't know why, because i have desassembly the phone without problem..
Few days later, i need to charged 3/4 times my iPhone per day and it's a new Battery ( very good quality buy here) and my External Speaker Doesn't Work...
What can i do ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Have you tried to restore from itunes?
完成的
添加一条评论
3个答案
已选择的解决方案
You may have accidentally damaged some components during installation. Have you inspected the ribbon cables to see if there is any damage? It's always a good idea to go back through and make sure all the connections are clean and fully seated. You can clean them with isopropyl alcohol on a cotton swab, and make sure they're completely dry before you close up the phone again.
Does the home button click function still work?
这个答案有帮助吗?
得分 1
1条评论:
Yes the home button Work, just the Touch ID and the external speaker doesn't work..
完成的
添加一条评论
Download a programme on laptop called ibackup bot it will actually tell you how many times the battery has been charged..
Most new batterys you get are never original and have been charged I've 100 times unless you have a good supplier
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem, found sensor cable was not seated fully. Took quiet a few goes to get it right.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
robinphi58 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 274
