跳转到主内容
The Nexus 6 is an Android phone developed by Google and Motorola released in 2014 with a 6-inch display.
68 个问题 查看全部
Can I fix my cracked screen myself?
I have a Nexus 6. I dropped it. Shattered my screen. Where would I find the instructions and what tools to use?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 14
1条评论
It is very difficult to change just the broken glass, but you can get it done here for a good deal: http://www.ebay.com/itm/Nexus-6-Motorola...
完成的
添加一条评论
4个答案
最有帮助的答案
It seems like this instruction is for the entire display. Is there any way to replace just the glass?
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
Please see the following guide on replacing the display assembly for the Nexus 6: Nexus 6 Display Assembly Replacement.
这个答案有帮助吗?
得分 0
添加一条评论
https://www.youtube.com/watch?v=iNSUOpRU... Here is glass repair only.
这个答案有帮助吗?
得分 0
添加一条评论
I wouldn't advise replacing the glass yourself. It appears to be a complex process as the glass is glued to the LCD display. If the LCD isn't cracked, it is worth a try. The alternative is to replace the LCD digitizer entirely. Currently the LCD digitizer cost approx 180 USD and fairly easy to install, providing you follow the guides and have the right tools. I would advise you to replace the LCD digitizer, buy a glass screen protector (the replacement digitizers from China are not Corning Glass) and a new case to better protect your phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tammy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 9,042
