跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
问题已关闭
Split Screen? green lines and half the screen appears?
So I had the screen replaced on my 5c about 6 months ago. It has been working fine. The other day I tried to turn it on and there are green lines going up and down on half the screen. I can see my lock screen on the other half, but cannot open the phone. If someone calls I can answer, but can't text or open any notifications. The part of the screen I can see it the left side - so I can see there are texts and notifications but I can't open them? HELP... I don't want to have to get a new phone!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
A couple weeks ago there was some kind of update sent to my phone and since then my phone got slow and sluggish and occasionally turning off to 0% battery once my battery got below 20-30%. then eventually, after one of its shutdowns last week, I just got a blank a white screen with some lines (kinda looking like a poor tv signal except no movement).
完成的
添加一条评论
2个答案
最有帮助的答案
Sounds like the screen is just damaged or the connections are loose
这个答案有帮助吗?
得分 2
添加一条评论
First, take a look to the LCD flex cable connector if is it broken/damaged.
Second, LCD flex cable is not well connected to the LCD connector.
If everything is fine, your LCD is damaged.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 770
