跳转到主内容
加入维修社区 - 创建账户
无线连接并控制您的苹果电脑。
Why "k" key doesn't function?
Hi, the "k" letter of my keyboard is dead, I tried connecting my keyboard to two different machines (Mac and Win) with the same results. I tried to take the key off and clean it, but nothing changed.
Any ideas??
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
I have 3 original Apple wired keyboards all with a malfunctioning K key - typing anything with a "k" included needs visual check to ensure it appears... otherwise its repeated tapping to get a response.
完成的
Had the same problem with letter Y...if it' not a software issue like speech dictation or similar, or mechanical issue like spilled liquid try removing the cap of the letter than adjusting the rubber connector...than take a pointy object and try pushing the key and gently adjusting the rubber connector. It has worked for me
完成的
添加一条评论
1个答案
已选择的解决方案
Here's the only solution I could find to a single malfunctioning key on that particular keyboard: http://www.omninerd.com/articles/Apple_C...
这个答案有帮助吗?
得分 4
3条评论:
Thanks Mayer, I only press the k key, but nothing happen, upper o lower case is the same.
Thanks a lot
完成的
Thanks
完成的
That site appears to have been hijacked.
完成的
添加一条评论
添加你的答案
mvmarroquin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 26
总计 18,829
