跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
My iPod won't turn on!
I recently replaced the lcd/digitizer and i cut a random ribbon that was under the metal plate. Now my ipod won't turn on. I can have a picture for you...http://cdn.imore.com/sites/imore.com/fil...
The cable just above the battery is cut in two for me... can someone help???
also... it could play music with voice control but the screen doesn't turn on :(
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
its your power button and volume ribbon cable. replacing the cable will fix your issue but it requires steady hands and soldering.
这个答案有帮助吗?
得分 0
1条评论:
really??/ thx i could do it... i am young and have steady songs... but it could play songs with voice control.... so..... it actually works???
完成的
添加一条评论
此回答最初是针对另一个问题
start to lightly tap it, maybe it will snap loose.
这个答案有帮助吗?
得分 0
2条评论:
yeah it didn't work but thx anyways :)
完成的
the only other thing to fix it, is to take it apart and replace it. the only thing to get it working now without fixing it is to turn on touch assist in your settings to give you a on screen button to use as a power button. settings - general - accessibility - assistivetouch.
完成的
添加一条评论
此回答最初是针对另一个问题
Try a hard reset by holding the home and power button for 10 seconds. If that doesn't work it is possible that the LCD is unplugged or the backlight is burned out. Was the ipod dropped or water damaged?
这个答案有帮助吗?
得分 0
1条评论:
uhhhhh i did hard reset like 10 times, and yes i have dropped it in water but then i dried it with a hair dryer and i but it in a bag of dry rice for 3 days. And apparently my power button and volume ribbon cable is cut...
http://cdn.macrumors.com/article/2010/09...
does replacing the lcd screen and the cable fix it??
and please reply asap
完成的
添加一条评论
添加你的答案
Justin Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 144
