跳转到主内容
A 32-bit fifth-generation video game console that was first released by Sega on November 22, 1994 in Japan, May 11, 1995 in North America, and July 8, 1995 in Europe.
22 个问题 查看全部
No power after brief flicker of the power light
Hi
I recently purchased a Saturn from eBay and after connecting it to my TV it seemed to be fine but after a few seconds the power went. If I leave it for a while and try again the power led will blink green and then it just dies again.
Could this just be a fuse issue as I cannot see any obvious broken bits on the power supply board (I have no meter to test the fuse)
Any ideas?
Thanks
Chris
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If you are doing repairs involving opening up a console, a multimeter is a must-have tool. From your description, I believe the issue is with the power board. I recommend checking the caps on the power board a second time. Do any of them appear bloated, even if they are not leaking? Normally, the top of the cap should be flat. (bloated caps can sometimes be missed if they aren't leaking.)
An issue with the fuse was my first thought, but if the fuse was blown, the Saturn wouldn't be getting any power at all.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Horne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 565
