Battery condition "Replace Now" after water spillage
Hi,
yesterday we spilled water over a MacBook Air 11".
I immediately shut it down and opened it to unplug the battery.
It seemed to have water only in the front part of the machine.
I removed the battery, dried the keyboard, checked that the mainboard is not wet and let it opened for hours.
Result:
- MacBook is starting with power adapter plugged in
- AHT is fine
- All keys, wifi etc is working
Problem:
The MacBook is only working with the power adapter. As soon as I unplug the system is down.
Battery Information is as follows …
Model Information:
Serial Number: removed
Manufacturer: DP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 301
Hardware Revision: 1
Cell Revision: 173
Charge Information:
Charge Remaining (mAh): 2344
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 3931
Health Information:
Cycle Count: 1100
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 7736
Do I need to replace the battery; I don't think so.
Is the MagSafe board defect? Or the logic board?
The light on the power cable is normal green.
The device does not make any strange noises.
I would appreciate any help!
Thanks,
Mike
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
