跳转到主内容
A home electrical installation is a complex system of electrical components that bring power into a home and distribute it to the various outlets, appliances, and lighting fixtures.
25 个问题 查看全部
sprinker system irrigation valve box outside and located above ground
The valve box is full of water and some water is pooling on the ground outside of the valve box and it hasn't been used for over a year. I see wires inside is it an electrical hazard to touch? If the water inside box is not normal how do I repair? It hasn't rained that much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’m not a professional by any means but I’ve done some work on the subject,, if there’s water in the box and it hasn’t subsided, that means there’s a leak somewhat, possible locations.
  • Cracked pipe
  • Solenoid is not fully closed
  • Screws on valve are not tight
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mwiggins 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 215
