跳转到主内容
BlackBerry's newest flagship that features a physical keyboard.
73 个问题 查看全部
Can blackberry passport water damage be fixed?
My blackberry passport fell inside water. i picked it and dried it and it worked for about a week till it suddenly went off and won't power up again.
I've taken it to the repair and i'm told i need to change the panel which is unavailable in the Nigerian market. please where can i get the panel. also will it be possible to fix this phone
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
No change for main board needed ask technician to remove ( brake ) one rectangular resistor between battery connector and display connector. If phone have water inside this resistor change and drain battery to 0 and prevent charge. I do same on may Passport and it working after one minute charging.
这个答案有帮助吗?
得分 0
添加一条评论
yes its possible the phone will work, what ill like you to do is to contact me or watsap me on 08030732622,you be happy you did
这个答案有帮助吗?
得分 0
1条评论:
hi chucks kindly sendme a watsap message on my contact,im based in Abuja we will discuss how in get the phone for repair
完成的
添加一条评论
添加你的答案
chukseboagwu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 1,835
