跳转到主内容
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Stylus doesn't work on touchscreen, but finger does
Two days ago the stylus started working intermittently on my Note 3 (SM-N900A) and then, very quickly, not at all. There was no obvious contributing event that could have caused it. The touchscreen still responds to a finger. I understand that there are two separate systems for the touchscreen, one for stylus-sensor and one for finger-sensor. I have tried two different S-pens and I've changed the tip on the old pen, but the touchscreen doesn't respond to any of them. A local repair shop told me that when the stylus no longer works, it's usually a specific cable that needs to be replaced, and that to replace it, you have to break another component. They wanted 100s of dollars to do the work. I'd rather do it myself, but I don't know what parts are needed. Can anybody fill in the gaps?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
1mm 3m double sided tape
blow dyer
guitar picks (6ish or more)
blue pry
patients
Disassemble back of phone.
Unhook the two screen ribbons, and front buttons ribbon as well.
Apply blow dyer at the screen with an equal heat spread all over the screen.
After 10mins but before you cant even touch it (too hot wreaks lcd)
Pry lcd top down guitar pics to keep separated and slide down both sides of phone.
Re-apply heat between lcd and frame as you progress. -keep the glue warm and loose.
Repeat method to remove stylus copper pad screen. -not as hot this time
CAREFULLY align new stylus board.
Run 3M tape around the frame to seal screen to frame, keeping dirt out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Debra Butler Lynch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,684
