跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
208 个问题 查看全部
interchangeable Logic Boards A 1347 mac mini 2012
Heya,
I sent you an email a while back about Mac Mini late 2012.
I probably didn't phrase the question correctly. . .
I have a mac mini 2012 with an i5 logic board in it. . .
I would like to put in an i7 logic board in it instead. . . very long story. . .
is this possible? Are the logic boards for the late 2012 mac minis interchangeable?
Please advise. . .
Kind Regards
Rob
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Well you are between a rock & a hard place here ;-{
At this point I don't think it's worth swapping out if your system is working. You can buy a used system for less than the cost of a replacement logic board (approx $750 U.S.)
As to your direct question you can replace the logic board within the same series without issue. In this case the i5 logic board (Macmini6,1) can be swapped out with either i7 (Macmini6,2) models being an exception to the general rule.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
rob Stewart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 529
