跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
Black display frame for anti-glare model?
Hi,
I'm about to get the new MacBook Pro with an anti-glare screen. As I like the black frame of the glossy screens a lot more, I would like to know If you know about any replacement parts or any other ideas to get the black frame on a anti-glare screen.
Thanks for your help.
Fabian
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Take it off and anodize it in any color you like.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi....
Your best bet would be to spray paint the silver frame.... (after you remove it of course) but the only problem is that it will no longer say Macbook Pro...
Please not that this and any modification WILL viod your warranty
Darren
Apple Certified Macintosh Technician
London, Ontario, Canada
这个答案有帮助吗?
得分 2
添加一条评论
The "true" black frame is underneath the glass, so I doubt it would be possible to do it with OEM parts. It's not like the frame on the anti-glare, which surrounds the display from the outside (you can touch it).
Makes you wonder though... If the frame dimensions are similar, might it be possible to disassemble a glossy screen, remove the frame, and install it on an anti-glare? Might be a fun thing to try if you had access to some broken screens.
这个答案有帮助吗?
得分 0
添加一条评论
"spray paint the silver frame"
brilliant
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fabian Nagel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 3,105
