I have a followup question. I spent most of the day today replacing the 25 1800 uF and 1000 uF capacitors on my mother's old A1058 iMac G5, trying to resurrect it. 6 of the capacitors had obviously bulging capacitors.
Before the replacement, LED 1 would light up, then LED 2 would briefly light and go out. Now LED 2 lights up solid, but LED 3 doesn't light up. I reset the SMU, still can't get LED 3 to light up. Furthermore, the screen is most certainly not getting a signal.
I am fairly confident I reconnected the inverter properly (checked it twice), so I am curious what people would suggest I try next. Do the LCD displays actually fail (maybe due to the blown capacitors) often, or is this more likely still a motherboard issue? Any suggestions for what to try next would be appreciated.
P.S. - I do not have an external display adapter to test with at the moment (I am trying to see if I can borrow one).
1条评论
Thank you Mayer and RJ for your most helpful comments. I was finally able to take the time to evaluate the G5. It seems that it only needed a cleaning up to this point. It is not overheating and the 1st 3 LED's light up as described. I installed Leopard, maxed the RAM to 2G and am looking at installing a Superdrive. I will then transition this unit to my kids so they can use it for school. I didn't want to drop a ton of dough for a new one if I didn't have to and hope this will serve for a couple of more years. Thanks again.-D
由 Dino 完成的
