跳转到主内容
Repair and disassembly guides for the Compaq Presario CQ40.
Why is my battery not charging
How i fix my loptap that cannot charge in if even the charger are conected my laptop doesn't work but if the battery is have charge its working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
最有帮助的答案
Sounds like either you charger or DC jack is faulty. Ensure all leads are properly connected. Test your charger using a multimeter for the voltage given on the sticker on the charger. If you are getting the correct voltage, it maybe the DC jack which is a common fault on laptops. You can test the DC jack by opening the laptop up and testing for voltage where the jack meets the board. If the DC jack and charger are working, the power board is probably at fault.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
louieokford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 2,868
