跳转到主内容
Laptop Screen regular horizontal lines
I have a Samsung NP350V5C which is briefly displaying horizontal lines over 75-100% of the screen, almost like interference.
The video is perfect on an external monitor, so GPU issues are eliminated and it has to be between the motherboard and the screen.
Thinking it was probably a faulty LVDS cable I replaced it with a new one - with no improvement.
I have noticed that the 'interference' is very regular - 1.5 seconds long, every 3 seconds.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
replace LCD, it is malfunctioning. LCD's are more fragile than you think- they can crack if you put pressure on the back of the notebook, or maybe you accidentally closed it with something in it. Before buying an LCD, make sure the pins on your LVDS connector on your mainboard aren't bent or deformed, as this may cause issues with displaying stuff. if all is clear, get the correct size LCD for your notebook. LCD replacements are easy!
I wish you good luck with resolving your issue, and if you are in doubt when purchasing your replacement LCD, I am here. If you don't feel up to it, Your local repair shop is waiting for you- they may even help you more than me with the part! just ask them if they can help you get a spare LCD for your laptop - they may let you buy it from them!
weeowey
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Geoff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 287
