How to replace touchpad without replacing complete palmrest/keyboard?
I have a Asus U56E I cannot figure out if the mouse touchpad is glued to the palmrest or how to replace it.
i used a heat gun on low
这个答案有帮助吗?
to remove it and once my new keyboard comes in i'll use a super blue to replace it back on
I just had to replace the touchpad on an Asus U56E and I also can confirm that it is glued to the palm rest. I too removed it with a heat gun on low. I heated the plastic touchpad on the top of the palm rest (not the touchpad circuit board itself on the bottom of the palm rest) for about 5 min at about 300 degrees & then was able to get a *very* thin pry tool under the edge of the circuit board & just slid the tool all the way around the edge of the circuit board, then heated it again for several minutes & then finally very carefully pried it off with a plastic pry tool. Even though the adhesive on the bottom looks a little messed up after prying it off, the circuit board still worked fine when I installed it in another laptop & in my case I was even able to reuse the adhesive.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 8
总计 1,209
