跳转到主内容
加入维修社区 - 创建账户
July 2013/ 1.0GHz ARM single core/ 4GB SSD/ 512MB RAM/ Android 4.2
Can you explain how to do factory reset
I put a child lock password n know I don't remember it. I am turning off the tablet by then holding the power off option then is asks about safe mode I say yes . It then says shutting down but when it restarts it is still locked
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
6条评论
To do a factory reset, when the device is off, press and hold the power and volume up buttons at the same time and hold for at least 10 seconds.
完成的
my tablet is running real slow and keep cutting off.
完成的
How can I reset it if it doesn't have the volume buttons.
完成的
followed instructions still reading wrong pin. how do you reset. Polaroid is the worst company to ask for help. All tablets should be recalled. A real waste of money. HELP for POLAROID
is a BIG NO NO> impossible TO GET HELP ON INTERNET OR ON PHONE. BIG WASTE OF MONEY ON MODEL M11H/Q1100 BE VERY CAREFUL NOT TO FORGET PIN. YOU CAN NEVER RESET TABLET.
完成的
I can't factory reset my tablet, what do I do now.
完成的
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
Erase data using the Settings menu
To perform a factory data reset using the Settings menu, follow these steps:
Before you reset your Android One, see options for backing up your data.
On your mobile device, open the Settings menu Settings .
Under "Personal," touch Backup & reset. You may need to enter your pattern, PIN, or password.
Under "Personal data," touch Factory data reset.
Read the information on the screen and touch Reset phone.
If you have a screen lock, you'll need to enter your pattern, PIN, or password.
When prompted, touch Erase everything to erase all data from your device's internal storage.
When your device has finished erasing, select the option to reboot your device.
You'll see the Welcome screen just as you did when you turned the device on for the first time. When you're done with the
这个答案有帮助吗?
得分 1
添加一条评论
this will not reset, you have to use Adb command or you can reflash it.
这个答案有帮助吗?
得分 0
3条评论:
I just want to get this fix , so that I can use it.
完成的
is there a place to send it to get fix.
完成的
I only had this tablet for one year.
完成的
添加一条评论
Como la uso con que le salga unfortunely, KIDO'Zhas stopped
这个答案有帮助吗?
得分 0
1条评论:
Nunca e podido usarla
完成的
添加一条评论
添加你的答案
Wendy Olivas 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 43
总计 2,850
