跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
iPhone 6 antenna problem
I have network problem with my iphone 6.
The problem is sometime i lost signal. I have analize around and found that i have problem with my antenna. When i lost signal all i need to do is squeeze my iphone and the signal will back to normal.
My question is ;
How is bottom antenna work? I heard that iphone 6 use bottom part as the antenna itself but where is the connector. I only found one connector bellow battery connector and then no more so how i can fix network problem on my iphone?
Please dont ask me to reset since i already fix and now that this problem is hardware problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
最有帮助的答案
This should not be related to the antenna.
iPhone 6 has at least 2 antennas for cell signals and they work at the same time. One is the top band and the other is the dock flex with the bottom band. The lower RF coax cable from next to the battery connector goes into the dock flex and the flex is screwed down onto the band.
If the phone just loses connection when the signal is not bad, usually it's more likely that the cell tower setup/SIM card/baseband firmware is the problem.
这个答案有帮助吗?
得分 1
1条评论:
Would this be picked up by apple on a diagnostics check ?
完成的
添加一条评论
Change antenna switch ic
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeandseen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 9,152
