跳转到主内容
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 个问题 查看全部
Increased difficulty starting in higher temperatures
In earlier years, I did not need to connect my 1983 300 TD MB station wagon, parked outside, to electricity until the temperature was below 32. In recent months, it was having some difficulty starting in the 40s.
Does this change result from the age of my glow plugs (5 or more years) or something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
This may be related to one or more glow plugs operating at less than full efficiency. You can use the guides here to see how to test and if need be replace them.
The next most likely culprit is valves out of adjustment. If you haven't adjusted them in the last 15,000 miles then they are overdue. If they are too tight you will lose compression in your cylinders as the valves won't close entirely.
This could also be related to fuel filters (restricted fuel flow), lower engine compression due to wear, or other items but the first two are the most likely cause.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Rennie Renberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 89
