跳转到主内容
the Dell Dimension 8300 was a high-end desktop hailing from 2003. it has socket 478 processor support and came with 4 GB of ddr2 RAM
Why will my PC not boot from SATA Solid State Drive
I upgraded by adding a SSD via SATA port on the motherboard. It works fine but will only boot if I also have a (redundant) operating system (Windows XP) on the original IDE drive. I can then choose to boot straight from Windows 7 on the SSD. Without the IDE drive I get a boot error something like Primary Hard Drive Not Found.
The IDE drive has now developed a fault and I want to install a new hard drive on the other SATA port rather than replace with in IDE drive.
Can anyone offer advice? DM.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
All done and working, thanks.DM
完成的
cuando prendo mi pc,, me dice que no tiene dusco duro por que, si solamente lo quite para checar otra computadora y al insertalo de nuevo me aparecio que no tengo disco
完成的
添加一条评论
2个答案
已选择的解决方案
You may need to alter the system BIOS settings so the SSD is set as the boot drive. Or, you'll need to swap the data cable connections between the drives.
Download the systems manuals from here: Dimension-8300 Manuals
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
The bootloader for Windows 7 has likely been installed on the IDE drive. This allows you to boot to other OS installed on your PC. The bootloader installs on the primary drive, which sounds like thats your IDE drive. That could be why it won't boot to Windows 7 when the IDE drive is removed.
Have you tried removing the IDE drive and then doing a fresh install of Windows 7 on the SSD. You may need to access the bios settings by hitting F2 when prompted after powering on the PC. Check the hard drive settings to make sure SATA is enabled not IDE and that the SATA drive is set as the primary boot drive. This may allow you to install and boot Windows 7 on the SSD.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Delta Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 22
总计 3,311
