跳转到主内容
加入维修社区 - 创建账户
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
Clock Repair - Does not work
Mercedes 1981 240D
Clock stopped working; how to repair?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hello,
The failure of the clock is almost always due to failed capacitors. There are two capacitors on the back of the clock that, with age, stop working properly.
You can follow the cluster removal and odometer repair DIY's to guide you through taking the cluster out of the car, and removing the various items from the cluster to get at the back of the clock.
From there, at this time, you'll need to find another source for a guide on how to actually remove and replace the capacitors as there isn't one on iFixit yet. Generally speaking it's a matter of de-soldering the old capacitors so you can remove them, and soldering in the new ones. If you are unfamiliar with soldering you might need to ask for help from someone you know who is good at it, or you can consider sending your clock out for repair. There are several companies that repair instruments from these old European cars.
Here is a link to the best info I've found so far on clock repair:
http://www.benzworld.org/forums/w123-e-c...
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
rochella williams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 3,089
