跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Replaced battery and the screen is now messed up.
I need help! I had a failing bettery in my iPhone 5s, so i purchased a new battery with the toolkit that was required to disassemble the iPhone 5s. I took apart my phone while watching a tutorial so i wouldnt mess up at all, i did everything exactly how i was supposed to, but it didnt work. The new battery was putting out a charge because the screen lights up when i press the home or power buttons, but the touch is rarely recognized on the screen, and the screen looks like an old TV set on a blank channel (just a black or light grey screen with a few different colored lines/rectangles). As you can probably tell, this is not supposed to happen. I think i may have damaged the digitizer cord and the LCD cord, but i really dont know and i really need to be able to use my phone this next week. Please, anything that comes to mind just write it down, even if you dont think it can help! I really need my phone to work!!!
Also it takes charge, siri function works, the only problem is the display on the screen and the touch recognition, for as i said the screen lights up and shows lines or rectangles...
Hope somebody can help, Thanks!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
I really need my phone soon, so i ordered a whole new screen with the home button, front camera, and all the cables attached. So when that gets in i will swap screens and hopefully that works, but i would still appreciate it if any of you think you know whats happened. thanks!
完成的
添加一条评论
1个答案
This has happened to me too. The best thing to do is cycle the battery -
1. Disconnect the display data cable
2. Disconnect the battery connector
3. Reconnect the battery, then the display cable.
After that, the display should be working better. You may have to do this a few times.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 949
