跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
202 个问题 查看全部
Which replacement to use for a weak USB port?
My USB port seems to be weak. It's only charging if I hold the cable in a certain position.
Cleaning the USB port didn't help and I tried several different cables.
Want to replace the USB port and I'm wondering what's the difference of the "Charging assembly" and the "Headphone jack and USB assembly"?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
In fact, they are the same thing. But USB port is different from the assembly. HTC One M8 charging assembly also called USB board is coming with USB port and headphone jack just like that. It's much easier to replace the whole assembly if you need to repair. While replacing USB port only is a little difficult and complicated because it need to be soldered.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Philipp Hofstetter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 236
