跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
External Case for PCIe SSD
Is there any external case for a PCIe SSD from the early 2015 MBPr?
My Macbook is broken, I want to sell it, just not with my data on the SSD.
Martin
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Your system is so new I'm not sure if this will work: OWC Envoy USB 3.0 case. Give OWC a call to double check.
How bad is it? Apple might fix it for a bench fee.
这个答案有帮助吗?
得分 2
2条评论:
Thanks, I'll have a look, if I can order the case in Germany.
Sadly Apple Germany won't fix it, because I dropped a glas of water nearby my macbook. :( Apple Germany does not fix liquid damage at all.
A 3rd party service center (Gravis) said they have repair guidelines from Apple, which force them to change every part which had contact with water - even if this could be no problem. In my case this means 1400€ (1500 US$). So I declared it as economic total loss.
Now I just want to sell the parts, but not my data. ;)
完成的
Sorry to here that. If the case works let us know. Good Luck!
完成的
添加一条评论
Hi msc,
I'm currently having a similar situation (very similar, actually...) and was wondering if you've been able to make any progress with this? Did you end up ordering the OWC case? Or did you find an alternate solution?
Liebe Grüße aus Berlin,
Mathis
这个答案有帮助吗?
得分 0
2条评论:
Hi Mathis, sorry for the delay.
Acually I solved it with buying a new Mac and switching the SSDs for formatting the old one. This worked out quite well, but it is surely no solution for everyone.
Even the guys at the Apple Genius Bar do not have the tools for formatting the SSDs - which is hard to believe. But this are the official words from the Genius Bar in the Apple Store in Hamburg.
Martin
完成的
Yup. Thats the only way to do it when there's no external case for it.
完成的
添加一条评论
添加你的答案
msc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,399
