跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
348 个问题 查看全部
dropped 3ds and need help its perfectly fine but wont turn on.
Hey I accidentally dropped my 3ds while playing a different game and now it wont turn on I press the power button and then the light turns on for a couple seconds then it turns off can somebody please tell what happened to it and how do I fix it please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Have you tried opening it up? It's pretty likely that a part inside has been disconnected or broken. Check out iFixit's teardown for a good idea of what the inside should look like.
If everything else looks good, another possibility is that the battery has been screwed up and needs replaced.
这个答案有帮助吗?
得分 0
1条评论:
I had a simar problem except I didn't drop mine. My new 3ds will not turn on at all, just play button sounds and system audio for a short time. Good luck man, new 3ds is extremely flawed, it's only a matter of time before everyone finds out.
完成的
添加一条评论
I know what happend the ribbon cable got disconnected
这个答案有帮助吗?
得分 0
2条评论:
@sqwerky, can you elaborate on your answer? You say "the" rather than "a" ribbon cable got disconnected, implying you have a specific one in mind. Which one are you thinking it is? There are, after all, several ribbon cables inside.
完成的
sorry for the extremely late response
完成的
添加一条评论
添加你的答案
some guy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 1,366
