Canon 28-135 f/4.0 IS USM Lens resist on turning
Hey guys
i totally no idea why does my lens resist on twisting whenever i zoom in or zoom out, i does require a certain amount of force just to twist the barrel of the lens.
how to fix this?
Hello Jan!
if the barrel is broken, you will need to replace it and additionally buy the CANON EF 28-135MM F 3.5-5.6 IS BASE ZOOMING GUIDE by $6 USD
http://www.procamerarepair.com/search.as...
i EXPECT can be usefully my answer.
good luck!
这个答案有帮助吗?
The same thing happened to my lens and I tried to zoom in and zoom out forcefully and suddenly it snapped and a ring broke in my lens so don't try to apply force. I watched this video on YouTube to fix my lens but I seriously advise you to get it fixed if you don't want to try to fix it by yourself still I am copying the link to the video. Hope this helps.
这个答案有帮助吗?
my lens is stuck at 135, i mean it believes that is at 135 even though i am at 28, anyone knows something about that?
这个答案有帮助吗?
It could be that the lens threads are out of position with a slightly bent lens.
This has helped me getting it fixed, maybe that also helps others
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 37
总计 4,197
1条评论
I have the same problem and it has gotten worse to the point that the lens is almost unusable
由 Gerald Hayken 完成的
