跳转到主内容
加入维修社区 - 创建账户
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
3DS won't stay stay on - makes a popping sound
Hello,
Recently I changed my 3ds LCD screen.
But once I tried to turn it on, it made a popping sounds and turn itself off after a few secounds.
I read about lossen ribbons and stuff, so I tried to disconnect everything and turn the 3DS on just to see if the motherboard can light up.
The blue light turns on for a few secounds before shuts off.
Could it be a blown fuse? I saw once that with blowen fuse the nintendo won't turn on at all..
What could be the problem? I discconected EVERYTHING, even the mic, and still it won't stay on!
Thanks.
- Theres no SD card inside.
- Theres no game inside.
- tried putting the motherbord inside a fully functationing 3DS XL.
- It charges.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
When it shuts off does one of the screens flicker for a split second? If the bottom screen flickers then there may be an issue with the top lcd. The 3d flex cable is usually the culprit. The ribbon may have a slight tear that is preventing the top lcd to power up which results in the blue light shutting off. To replace it requires a complete tear down of your system.
这个答案有帮助吗?
得分 0
1条评论:
No flicker when I turn it on.
完成的
添加一条评论
It absolutely will not power on if any of the ribbons are ripped or disconnected. Try reconnecting everything and look if the cables are ripped.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ChubbyKai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,288
