跳转到主内容
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Difference between ipad mini lcd and ipad mini 2 lcd
Hi, I have a bunch of iPad mini LCD's and I'm curious if there are any physical differences (not talking about resolution here) between ipad mini and mini 2 LCD's? I have a lot to go through so any difference that I can quickly glance at would be very helpful.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
I've found a difference.
If you're looking at the LCD from the back there is a small cable on the right.
On the Retina displays the cable comes up from the bottom of the display.
On the non-retina displays the cable comes from the side of the panel.
这个答案有帮助吗?
得分 2
1条评论:
Would like a photo if possible
完成的
添加一条评论
You know, I'm pretty sure you're right. But while looking for both images to show side by side, Google shows both the ribbons the same. I did notice the strip across the bottom missing from the mini1. Tho I can currently only vouch for the mini2 in front of me.
-Both of these images are from a Google search result. I am not the photographer. All credit goes to them, and all that jazz.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RegencyTech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 2,614
